Go Back   maXbimmer Forums > Classifieds > Group Buys/Specials/What's New?
Old 05-03-2012, 11:28 PM   #1
BimmerBoys
BimmerBoys's Avatar
E36 adjustable rear control arms
There are two types
Type 1 (one) is a standard adjustable arm. +3 to -1
Solid steel construction. 225$
Type 2 (two) is an aluminum arm. +3 to -1
Aluminum construction light weight. 315$
Made by Eibach/SPC
File Type: jpg 1323_eibach_pro-alignment__31356_zoom.jpg (7.3 KB, 165 views)
BimmerBoys is offline   Reply With Quote
Old 05-04-2012, 12:23 PM   #2
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
Are the rubber bushings replaceable on either one?
Old 05-04-2012, 01:54 PM   #3
BimmerBoys
BimmerBoys's Avatar
Just from looking at it on my work bench I'd say yes, but let me call eibach and double check it with them.
Old 05-04-2012, 01:58 PM   #4
I assume they are oem bushings? Maybe when you call you can confirm.
Dare I squeeze
Old 05-04-2012, 03:24 PM   #5
BimmerBoys
BimmerBoys's Avatar
Called eibach. Yes indeed the bushings can be changed. There is a kit availible from eibach/spc or oem can be used, but eibach recomends buying their kit... Of course.
Old 05-14-2012, 03:42 PM   #6
Axxe
Axxe's Avatar
How critical is the extra weight of the steel arm? From what I gather, they are heavier than the stock arms? Would you be able to get pricing on the TMS (rubber bushing) arms? I think they go for $300 USD, might be able to get a discount in bulk.
Also, where are the Eibach/SPC units made? USA?
Old 05-14-2012, 03:52 PM   #7
BimmerBoys
BimmerBoys's Avatar
Eibach is american made yes. They are a decent quality producer.
I'd rate their products as street/track, meaning that they are not
entirely race oriented. The weight will be a touch more than the stock
Arms, but in a lot of aplications weight reduction isnt the goal. If you're a competative racer then perhaps tms or some other arm is a better choice. If you want to improve the strength and adjustability of your rear camber than these kits are perfect!
Old 06-05-2012, 11:21 AM   #8
I've got the aluminium ones and they're great - easily adjustable.
FYI i think you have your adjustment specs wrong - should be -3 to +1... not the other way around
Great price too! - Look BW to compare:
http://store.bimmerworld.com/adjusta...46z4-p663.aspx
GLWS!
