03-08-2012, 02:19 PM
#1
Car: bmw
i'd like to borrow RTAB removal tool in GTA
anyone? thanks
03-12-2012, 12:07 PM
#2
Car: 98 M3 99
make one, pipe caps and threaded rod.
FYI, removal isn't the problem, pressing them back in is. To remove them just cut them out.
03-13-2012, 11:44 AM
#3
Car: bmw
thanks man, i'll google how to make one
03-13-2012, 04:20 PM
#4
pod stromom
Car: 325is 328is
dont bother with stock rtab and making tools! Just buy poly bushings, they press right in.
I've done both and I can tell you get the poly urithane. for the extra 50$ the time and effort you save are well worth it!!!
03-13-2012, 05:12 PM
#5
12 Years with the E30
Car: 325i 1987
That's right... pull the subframe ... apply propane torch to metal surrounding the tab, wait for yummy sizzling bacon sound... use any method desired to hammer, pull or yank them out...
Are they grouchy? apply more heat. Repeat.
You can do it with the subframe on the car... to do this effectively you do need a tool, or make a tool.
03-13-2012, 07:34 PM
#6
Car: e36 328is S/C'd
Yupp mines are poly too... to take them off i used a drill with a round bit (deep enough to go atleast half way) and cut out the middle.
>>>>WTB: Clean Estroil e36 Shell!! Pm me!<<<<
---------------Work In PROGRESS---------------
e30 325ic -
e36 328is - * Winter Mode *M50 Mani, 3.23 LSD, M3 Brakes, Intake, Spal fan, poly RTABs, Eibach Swaybars, Koni.
PREVIOUS CARS
'01 Audi A4 B5
'99 Integra Type R t3/t4 Turbo
'96 Civic B16
'95 Acura Legend Type II
'97 Euro Estroil E36 M3 Vert
03-13-2012, 07:55 PM
#7
Car: bmw
do i need limiters for poly rtabs?
what is a good place to buy them?
03-13-2012, 09:19 PM
#8
Stance is Gay.
Car: '06 325i
I'd personally go with OEM mounts. Poly starts squeaking after a while.
Also, it is impossible to use limiters with poly. They already completely limit the trailing arms movement. Which is a bad thing actually.
03-14-2012, 05:46 PM
#9
Car: e36 M52 330i
Despite what is mentioned above, if you still want poly bushings, mine are for sale.
03-14-2012, 09:13 PM
#10
Banned
Car: audi
 I used a drill with a round bit
03-14-2012, 09:15 PM
#11
Car: 98 M3 99
poly is not advised, yes they are easy to put in, but the joint moves in more than one plane
03-15-2012, 08:21 PM
#12
Car: bmw
i've done some research and decided to go for the OEM ones with limiters. thanks everyone for your input.
03-16-2012, 11:14 AM
#13
Car: '04 330CI 6-speed
I made a tool that you can borrow. You'll have to come to Guelph for it though.
