01-22-2012, 06:26 PM
#1
2nd Gear Newbie
Car: 1992 325is
oil housing gasket part number - m50 e36 92
Hi ,
trying to fix an bad oil leak on my e36. i check real oem and my oil housing do not match. i have two little oppenings that require a gasket. they are secure with metalic rings. please see pictures.. does any one know the part number for the gaskets and the rings. i have a 1992 e36 325is coupe.
Thanks for your help.
01-23-2012, 09:51 AM
#2
2nd Gear Newbie
Car: 1992 325is
just talked to the dealer.. these plp have no idea what it is because their diagram shows a different layout (same as real oem). The car is mostly stock so the odds are oil housing is original from factory. Good to know they are great help!! lol..
If anyone have experience with this type of leak please let me know.. thinking of using one of the make a gaskets products.. what u guys think?
01-23-2012, 10:17 AM
#3
Car: 2007 328XiT
The seem like your basic O rings ... can't match them at a hydraulic supply or something? They don't seem to be available as seperate part for any year filter housings
01-23-2012, 10:27 AM
#4
Car: 95 325i 4 door
you can buy one of those o ring kits at princess auto. im sure those will work there
01-23-2012, 03:34 PM
#5
2nd Gear Newbie
Car: 1992 325is
thanks for the reply.. will check out princess auto this afternoon and top off their gasket with the "make a gasket product" just to be in the safe side !
01-24-2012, 01:29 PM
#6
2nd Gear Newbie
Car: 1992 325is
got some look alikes from princess auto but still leaking.. been reading about this topic in other forums and apparently BMW do no sell these o-rings they want you to buy new filter housing. It has been suggested in other forums to use Viton 1000-118 o-rings... Any ideas where I can buy these in ontario?
01-24-2012, 02:21 PM
#7
Car: 95 325i 4 door
were the o rings thinner than the oem ones?
01-24-2012, 04:56 PM
#8
2nd Gear Newbie
Car: 1992 325is
well keep in mind that the original ones are pretty flat and hard just from being in that car since 1992. I just picked up a set that look similar and that fit the cilynder. On the site note I did not apply the make a gasket product. I am guessing they were a little too small.. or too much pressuere caused the leak
01-24-2012, 05:42 PM
#9
Car: 95 325i 4 door
you can try some quality sealent along with the oil rings, give it sufficient time to dry and it should be good to go. key word here is should be
01-24-2012, 06:56 PM
#10
2nd Gear Newbie
Car: 1992 325is
hahah thanks .. i ended up ordering the viton rings from USA.. want to make sure no more leaks (today and in one year +) .. my driveway already looks like crap... order is min 25 gaskets.. If anyone has the same problem let me know, i will have spares next week..
thanks for your help
01-25-2012, 10:09 AM
#11
Car: 325
I replaced mine last winter too with dealer OEM parts but had to give them the part number.
Part number was hard to find on the web, so I think I kept the baggy or wrote it somewhere. I'll check at home tonight and get back to you.
01-25-2012, 10:10 AM
#12
Car: 325
oops, just saw your last reply. I'll try to find it anyways if it may help others.
01-25-2012, 07:44 PM
#13
Car: 325
Part # 11-42-1-709-513, dealer charged $6 each!! Fit seemed too large but it stopped the leak.
Found it on this forum last year:
http://www.bimmerfest.com/forums/sho....php?p=4701933
