Old 10-02-2011, 02:36 PM   #1
Bimmerized
In BMW We Trust!
Bimmerized's Avatar
Send a message via MSN to Bimmerized
Weird electrical problem? Please advise
93 318is
I was driving the other day, and the cluster just went crazy, all the lights came on, the dials were going all the way to the end (similar to the calibration that you can do while holding the reset km button), and went back to normal.
Again today it did the same thing, first it went off, I was doing about 90 and it dropped to zero, all turned off, and then it did the calibrating thing again and went back to normal. This does not affect the drive, doesn't shut off the car, or anything, it looks like just the cluster.
What the hell is going on!?
Bimmerized is offline   Reply With Quote
Old 10-02-2011, 10:08 PM   #2
Daneee
be cool
Daneee's Avatar
Send a message via MSN to Daneee
Originally Posted by Bimmerized View Post
93 318is
check the plug behind the cluster
but
this is common problem with the E36
best way is...try an another cluster
suck the fish
Daneee is offline   Reply With Quote
Old 10-03-2011, 05:25 PM   #3
5style
Hatters gon Hatt
5style's Avatar
Alternator is on its way out, either voltage regulator or diodes, my cluster did the same thing I thought i.was seeing things. The guages would drop to zero and then go to normal without me touching anything. Next the alternator diodes completely died an that was that. I got a rebuild and installed a new regulator I bought, and it stopped
Old 10-10-2011, 12:34 AM   #4
bmdbley'sBro
wouldu like some tinfoil?
bmdbley'sBro's Avatar
interesting.. that happened to me over the summer..cluster dying for a sec then coming back on..
and i had some belt chirp back then too.. now i hear a belt or pulley chirp for like half a second on 1st cold startup..
bmdbley'sBro is offline   Reply With Quote
Old 10-10-2011, 10:04 AM   #5
jeffrie
Addict
jeffrie's Avatar
Belt chirp your talking about is likly the belt tensioner dieing on you.
Common for us 4 pots at the 200K + mark, not hard to change either.
"They say ignorance is bliss..... I don't know what the Fu*k that means but I'm pretty happy". Ricky Trailer Park Boys.
Current Mods....X-Brace, Stromung Cat Back Exhaust, 17/225/45 M3 Replicas, HotBits Adjustable Coil Overs, 40% LSD 3:91 Diff, E30 Gearbox, Boosted.
jeffrie is offline   Reply With Quote
