Old 08-07-2011, 11:10 AM   #1
Blown M3
E46 M3 6 Speed Install in E36
I was just wondering if anyone has installed a E46 M3 6 speed transmission in there E36?, and if so how much work it is to install. I have a Euro 6 speed E36 M3 tranny in the car now but it is finished and can't find one due to the fact that they are hard to come across. so I was thinking of a E46 M3 tranny BC they are alot more common. Any help would be appreacted.
Blown M3 is offline   Reply With Quote
Old 08-07-2011, 07:22 PM   #2
TitansilberM
Everything you need to know is right here http://www.nexternal.com/uuc/article...issionswap.htm
This winter season I have plans for the same thing along side a turbo kit
TitansilberM is offline   Reply With Quote
Old 08-23-2011, 12:22 PM   #3
Discostar
Discostar's Avatar
I'm in the process of doing this right now. If you currently have a euro 6-speed then you'll have everything you need, less the actual transmission.
So it would pretty much be a direct swap between the two.
Old 08-24-2011, 01:40 PM   #4
Jon@Bimmersport
Jon@Bimmersport's Avatar
If using the E46 M3 Transmission, the E46 M3 clutch and flywheel MUST be used for it to fit. I believe the E36 M3 6 speed keeps the same E36 clutch/flywheel.
E46 M3 Flywheel/clutch
E36 325i Slave cyl (to have the best pedal feel and engagement)
Authorized Ontario dealer for Active Autowerke|VF-Engineering|AFE|Bilstein Suspension|H&R Suspension|KW suspension|Brembo Brake Systems| Stoptech| - Call us for the best pricing
Jon@Bimmersport is online now   Reply With Quote
