10-15-2002, 11:33 PM
Car: MY04 325iT
how to remove the front bumper
The front bumper is secured in three places, the front, the underneath edge and the rear edges :
1) - lever out the long black plastic trim strip that is on the right of the number plate and theshort one on the left of the number plate. Behind each of these you will find two nuts that need undoing using a 13mm socket.
2) - In each wheel arch at the front is a further screw that secures the bumper to the body, turn the steering wheel to full lock turning the wheel inwards for the side you wish to undo, e.g turn the wheel left to do the righthand side.
3) - Underneath the bumper at both ends is a triangle shaped piece of plastic held on by 3 screws that needs releasing from the front edge of the bumper.
Once these have all been done carefully pull the bumper forwards until its free. WARNING If the bumper painted do not put it down on concrete or gravel as it will take the paint off so either put it on some grass or onto cardboard
2004 BMW 325i Touring SGM
2005 Suzuki GSXR 1000|1992 JDM Civic SiR RHD Black
2000 BMW M5 Avus Blue (GONE)
2002 BMW 325i Touring TVM (GONE)
1994 BMW 325i Saloon Black (GONE)
01-05-2008, 04:48 PM
Formerly Flav_cool
Car: '98 328is + '94 325i
What if you got fog lights? Pull them out and disconnect?
1998 BMW 328is - summer
1994 BMW 325i - daily
1992 BMW 325i - totaled
1988 Mercedes Benz 190E 2.3-8V - sold
01-05-2008, 06:00 PM
JUICY J CAN'T
Car: S54 titties
just disconnect the wire, there's no reason to remove them.
02-06-2008, 07:46 PM
6th Gear Newbie
Car: 2012 135i
Sounds easy from the steps you listed.....is it as easy as it sounds for someone with little experience?
- 2012 135i
- 2012 128i *retired
- 1998 318 is *retired*
02-07-2008, 03:11 PM
Formerly Flav_cool
How can you disconnect the wire without first pulling them out?
02-07-2008, 09:56 PM
Car: 1993 325is
putting it back on?
is it just as easy to put it back on? sounds stupid but i always heard that it takes experience to put it back on so it looks right, i just cant figure out why that would be as it seems straight forward. what about new bumpers?
02-09-2008, 12:12 PM
6th Gear Newbie
Car: 2012 135i
Anyone know the answer?
- 2012 135i
02-13-2008, 06:07 PM
Car: Cayenne and 911
Below the bumper, there are triangle brackets at each end of the bumper which you can easily remove. Once removed, you will have access to the back of the fog lamps which you can easily disconnect the cable.
When assembling the bumper, the bumper will merely slide into the bumper mounts. You'll see the mounts at each end of the fender. When you slide the bumper in, tighten the bolts situated at the front of the bumper snug where you can easily move and align the bumper until you're satisfied with the position. Once you're satisfied, tighten he bolts. You can then proceed to plug in the fogs and assemble the triangle bracket beneath the bumper. Hope that helps!
10-11-2008, 08:18 PM
Car: Supercharged M3
I can tell you that after you remove the front bumper it will never be tight again unless you use new hardware.
02-03-2009, 09:47 PM
#10
Car: 98 M3, 04 330CI
removing front bumper
the fastest way is to let your son drive the car into a snow bank - this works best if he carries some speed into a turn and approaches the bank from an angle - if possible the snow bank should be solid ice, otherwise hand removal will be required to complete the work.
Used parts are available at a premium
02-11-2009, 12:13 AM
#11
Car: 3 series
Hahaha, Sadly I feel Davis speaks from experience.
02-20-2009, 01:44 PM
#12
94 318is
Car: 1994 BMW 318is
For a second I thought you were my father.
02-20-2009, 09:07 PM
#13
OH NO - not another son!!!
sorry --- no more low mileage Ti"s , in beautiful condition left to wreck - NOT WHAT??? - OK - there are lots of 3i8's left - I'll buy one tomorrow - go nuts!!
03-31-2010, 11:49 AM
#14
Captain Chaos
Car: 1997 328i
Anyone know of a more in-depth DIY for taking off the stock bumper and replacing it with a M3 one? I'd prefer one with more pictures if possible. I don't want to get halfway through it and then get stuck. lol
