maXbimmer Forums
maXbimmer Forums (http://www.maxbimmer.com/forums/index.php)
-   E30 (1983 - 1991) (http://www.maxbimmer.com/forums/forumdisplay.php?f=58)
-   -   Water under batt tray in trunk... (http://www.maxbimmer.com/forums/showthread.php?t=154285)
BMe30 11-11-2012 06:17 PM
I drained the water from that plug under the car... When i removed the battery to dry the remaining water i noticed that there was a tube connected to the drain plug.. But where does this connect to?
http://img.tapatalk.com/d/12/11/12/uzuzupe5.jpg
Any ideas?
craz azn 11-11-2012 06:18 PM
It's supposed to be for that overflow port on the side of the battery.
BMe30 11-11-2012 07:53 PM
Any idea where that water is coming from that stands under the batt tray?
BmW1819 11-11-2012 07:59 PM
Sunroof drain?? That looks like the battery vent hose
BMe30 11-11-2012 08:39 PM
How can i check if it is the sunroof drain?
frankie591 11-11-2012 10:23 PM
open your sunroof and pour some water down the back drain and see if it leaks into the battery tray. Could also be a leaky taillight gasket, or there is a grommet above the battery tray where your sidemarker light wire exits the car.
BMe30 11-11-2012 11:32 PM
^^^ thanks.. Ill give it a try
Slowered318 11-12-2012 03:36 PM
Might be the flap vent from the trunk to inside the rear bumper, thats where the sunroof drain should be if it's connected properly. It could also be your trunk seal, mine leaks a bit into the battery area when I wash the car or park nose down in the driveway.
BmW1819 11-15-2012 07:49 PM
Sun roof drains is a black hose that goes into that vent behind the bumper
BMe30 11-15-2012 08:08 PM
Thanks for all the info!
Im going to do some water tests this weekend after i fix my oil leak by the oil filter canister and the block. Very common on the m42 it seems
nonlocal 11-15-2012 08:25 PM
Connect the battery vent too! Acid from an unvented battery will rust your shit faster than a puddle of water ever would...
BMe30 04-04-2013 09:32 AM
So it turned out to be the gasket around the passenger side rear tail light. It wasn't seated properly.
BmW1819 04-10-2013 08:09 PM
Nice u silcone it?
BMe30 04-10-2013 08:58 PM
Originally Posted by BmW1819 (Post 1605636)
Nice u silcone it?
No.. The rubber seal around the tail light was not seated properly. I reinstalled the rubber properly and took care when reinstalling the tail light to the car. Did a leak test with my hose and it was dry. The past few days i left my car out in he rain... So far atill dry :)
BmW1819 04-11-2013 08:10 PM
Ahhh nice
