maXbimmer Forums
maXbimmer Forums (http://www.maxbimmer.com/forums/index.php)
-   E36 (1991 - 1999) (http://www.maxbimmer.com/forums/forumdisplay.php?f=59)
-   -   Whirring sound w/ RPMs? (http://www.maxbimmer.com/forums/showthread.php?t=108872)
dbworld4k 08-06-2008 09:35 PM
Noticed this today. Loud whirring noise that gets faster with my RPMs up til about 2.5K. It is very loud, and happens all the time when you rev the motor, whether in neutral or in gear. When idling, I don't hear it. Pressing the clutch pedal or not won't make a difference in neutral, it still makes the sound.
Any help?
Lower_Level 08-06-2008 09:43 PM
clutch engaged or disengaged???
My first thought would be either pilot bearing or throwout bearing
lukeh 08-06-2008 09:55 PM
the bearing usually won't do it when in neutral.
dbworld4k 08-06-2008 10:02 PM
When I attempted to re-create the sound in a parking lot, the clutch pedal was not pressed in, car was in neutral. Simply revving it in this condition made the noise come back.
propr'one 08-06-2008 10:08 PM
Do it with your hood open by manually opening the throttlebody. Could be the fan clutch.
kenmar 08-06-2008 10:50 PM
I've had 2 whirring problems: one related to the clutch, and one unrelated. When it was related to the use of the clutch, it was the throwout bearing. When it was unrelated to the use of the clutch, it was a bad serpentine belt tensioner pulley. If it's the tensioner pulley, it can fail catastrophically as it did in my car, leaving you with no alternator or p/s. Fortunately, I coasted into my garage as it happened :). Unfortunately, BMW no longer supplies just the pulley for my '94 and I had to shell out close to $300 for a complete upgrade to the hydraulic tensioner and pulley.
dbworld4k 08-07-2008 12:13 AM
I propped the hood open and had a friend rev the car, it sounded like it was coming from near the engine itself, not the front of the engine bay. I did notice the fan clutch spinning off axis, a bit wobbly. Perhaps I should do a FDM before it blows...
zimzimmma 08-07-2008 10:44 AM
my car was whistling just the same.. was the fan itself had a chipped blade on it.. replaced it and back to normal
